Discuss Plastic Tile Trim Removal in the America Tile Forum area at TilersForums.com.
11
Ireland
Hi all,
Is it possible to remove the plastic trim from the edge of tiling. I want to tile higher up the wall. See sceenshot attached.
Also, is it a must to remove, or could I just grout over it somehow?
223
Bucks
Agree with the comment above sharp stanley knife between the tiles and trim will cut and be able to remove easy. If you want to replace the trim your gonna have to take all the tiles around the edge.
USA
Removing plastic tile trim can be a straightforward process. It is important to note that the specific steps may vary depending on the type of plastic tile trim and the installation method used.
Reply to Plastic Tile Trim Removal in the America Tile Forum area at TilersForums.com
