Discuss Offset Window in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Razornut
Only a slight issue. Not my first rodeo but the window is off set to the left 120mm. I'm using 600x300 tiles, the wall is 370mm one side and 490mm the other I would normally even out the tiles around the window as that is a focal point. However the window is on the wall tat faces you as you open the door so having odd cuts on each side will also look odd. However I am edging towards evening out around the window. As the cuts will not be little slivers.
One Day
I've cheated before by cutting down the tiles which are central, up to 60mm off and it can be impossible to tell.
Razornut
Also chaps 2 walls are mosaic one on dot and dab the other studding. I really want to go down the correct path and take it back but her in doors gives me a head ache with the constant moaning about the mess. So here is the question.. And I can't believe I'm asking this.. Is it possible to tile over mocaics?
Reply to Offset Window in the DIY Tiling Forum area at TilersForums.com
mcgtech
