New bathroom install - stud wall question
sam_b
Been silently surfing in the background for a few days before signing up to get a few folks thoughts on a new bathroom I'm putting in.
I'll be building some new sections of stud wall for a shower cubicle (1100 x 900 - 1 existing brick/skimmed wall and the other 2 new stud sections). I'll be using shower panels inside the enclosure instead of tiling for ease of maintenance etc, probably with classi seal around bottom join.
Any suggestions as to the best product to use for the new stud wall sections:
Plasterboard (skimmed/unskimmed/tanked?)
Marine ply (tanked?)
Aquapanel (tanked?)
No more ply - believe it's waterproof from what I gather.
The floor's currently chipboard.... not my doing..... so I'm planning on taking it up and replacing with 18mm ply.
If tanking is the preferred option is there a particular one recommended, membrane v paint on? I see a sticky in one of the other forums mentioning the Mapei Shower Waterproofing Kit?
Thanks in advance,
Sam
i would use the aquapanel which is waterproof, just tank the taped joints. if the chipboard has no deflection then you could leave it there and just overboard with cement boards using spf and screwed every 150 mm, even if you decide to replace with ply you would still be better laying cement boards on it as wood is not a good substrate to tile on.
As above, when I did mine, I constructed a timber frame then screwed Wediboards onto that, taped all the joints with the wedi stuff, it is stuck on using waterproof adhesive then again over the top of it and all the screw heads were taped and covered in addy. Then tiled it and then did the floor, I did put two layers of 18mm ply over the chip board floor as suggested from this site and then wedi boarded that with one of Wedi's preformed floors, that was two years ago and no problems at all.
i bet you didn't need any steps to reach the ceiling :lol::lol:
Cheers for the replies guys.
Chipboard flooring is coming up anyway as there's a fair bit of re-piping to be done, section under the bath was already water damaged as well.....
Seemed to be a few conflicting comments on aquapanel being truly waterproof, as opposed to just not breaking down after contact with water?
Being in N.Ireland local sourcing the various boards is a bit of a pain in .... sometimes. B&Q do aquapanel (not the cheapest I dare say but an option) and I had found a place that did "no more ply", hadn't looked into any others yet.
Best job for sealing the floor to the wall sections around the shower cubicle just the tanking kit I guess, I see some places that do preformed corner membrane pieces.
Maybe I should confirm it's not a "wet room" type setup, there'll be a shower tray going in for the shower cubicle.
Strangely I didn't!! But seriously, the floor level was around 45mm below the door level so two layers of ply, plus a liquid screed over the electric heating plus a decoupling membrane then tiles, I stuck my hairbrush on the ceiling with some left over addy and now save time brushing my hair in the morning (if I duck) I can even scratch my back!:smilewinkgrin:
Meant to ask about the tanking kit too. Is it particularly "thick" when set, I was planning on building the new stud sections around the shower tray so I wouldn't want to do that, tank it and then find out it's a tight squeeze to fit the tray back in.... 😳
Bathroom Tiling Advice
Unsolved
sam_b,
Gazebo,
sam_b,
Gazebo,
