Discuss Laying travertine over ceramic floor tiles? in the America Tile Forum area at TilersForums.com.
P
posher
Is it possible to lay travertine floor tiles over an existing sound ceramic floor tile and if so what preparation is needed?
The Legend; Phil Hobson RIP
It is not really advisable to tiie on tile. Mainly because there is no way of knowing how well fixed the existing tiles are. If you dicide to risk it anyway, I would suggest Mapei keraquck with latex plus.
Hope this helps:thumbsup:
Deleted member 9966
Probably not the best of ideas posher. there's a ton of reasons why not. I'll let some of the other members explain
:welcome: to the forum by the way.
see ^^^^^^^^ Phil hits the nail on the head there :thumbsup:
david campbell
not got practice mate!
what for any reason the existing tiles de-bond?
your heights will come up almost 20mm under doors!
all cuts will have to be absolutely perfect unless you are removing the facings!
but if you decide to go for it i would also use keraquick and mapei ultracolour jasmine grout:thumbsup:
All good advice above, all I have to add is that whatever adhesive you choose, whether it's Mapei or another brand like Weber for example, it would need to be a single part flexi adhesive, preferably white, so that if you get any on the tile face you won't see any staining to the tile. :thumbsup:
DJS
If the sub-floor is wooden, then definately not. If it's concrete, then it's still a gamble.
I would't take the chance. If the floors not too big, then a morning having fun with a bolster hammer and cold chisel would remove the old tiles, the risk of them failing, and unneccesary weight on the sub-floor.
P
posher
Many thanks for all your replies. Well that's this morning sorted! Out with the cold chisel.
DJS
Hi and welcome BTW :welcome:
What kind of sub-floor do you have? Wooden/Concrete/Screed? Let us know if you need any more advice once they come up...good luck :thumbsup:
P
posher
The sub floor is concrete. What preparation/sealing will this need before I lay the tiles?
P
peegee tips
I've just been to look at a floor which has half quarry tiles & the other half a nice & flat screed. They have ordered travertine. Kitchen will have new units fitted.
The thing is, the tiles are stuck down well, & are perfectly level to the abutting screed, so would it be just making things worse by lifting them all up, plus all the extra work & cost of getting it all level again, when its all nice & level & solid to start with. Would you agree that as there is no heated screed & its been down a long time anyway that there is no need for a decoupling membrane.
Quarry tiled area is approx 7m2 & screeded 9m2.
Your thought would be appreciated please.
Hi Peegee,
before you consider tiling, get a moisture meter on top of those quarries, and check for moisture, if it's too high and it's an old house, the quarries will propably on top of cement thrown down on earth with no dpm, in which case you would have to latex screed over the quarries and the existing screed, apply an epoxy dpm then use a spf adhesive on top of the dpm which can be tiled directly onto, provided there are no pin holes, and the manufacturer of the adhesive allows it.:thumbsup:
Reply to Laying travertine over ceramic floor tiles? in the America Tile Forum area at TilersForums.com
Hi all, I want to tile over a completely new floor. New floor joists have been installed with...
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
Hi. Screed been down ten years, no issues . I’m about to start the mammoth task of lifting...
Hello I'm new to tiling my first flooring job it's 42sqm in 600x 200 floor tiles (wood effect)...
Hi, I'm tiling the floor of a wetroom and would like some advice on the best way to lay the...
Teejay
