Discuss Is this Addy ok for 20mm marble slabs in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
I dont like combing the back butter as it can ghost through hence ime thinking 15 mm trowel and just generously back skimming ,unlikely but as you say you can't be to carefully with this stuff,I will be spending some time prepping the floor there is some self leveling involved and yes clips.If you're buttering them then I'd use a 10mm for both to get a 10mm bed under them. Depends how level the floor is though, I guess. It could be too thin in places with tiles that big. I'd definitely use clips with them being that size on latex.
Standard as any other marble or natural tile:Customer has got this for 20mm marble floor slabs can anyone give me any feed back on it thanks not used it before thanks.
Ultra Tile Fix
Pro Flex Spes S1
Standard set flexi
Thanks, more or less what it is, what size trowel would you use ?Standard as any other marble or natural tile:
If the floor is really all over, level first with a suitable levelling compound.
Install a de-coupling membrane on the floor.
Level if necessary with a suitable levelling compound.
Tile with a white adhesive suitable for large format and to the conditions (S1/2)
If you are a messy tiler, or there will be heavy footfall in stages, I would suggest sealing all the stone prior to fixing. If not, just keep clean and seal 12 hours prior to grouting with Lithofin MN Stainstop or other.
20mm round-edge thick-bed-solid-bed (Californian)Thanks, more or less what it is, what size trowel would you use ?
That's exactly what I've been using for years never had had a problem.20mm round-edge thick-bed-solid-bed (Californian)
Me neither, so...?That's exactly what I've been using for years never had had a problem.
Just seen several other suggestions trolling through here and started doubting myself, wobt look no more.Me neither, so...?
As long as the floor is stable, flat, and de-coupled and use good gear, you shouldn't have a worry in world.That's exactly what I've been using for years never had had a problem.
Reply to Is this Addy ok for 20mm marble slabs in the Canada area at TilersForums.com
