How long do you leave porcelain to dry before drilling etc
L
LJD
Lucky it was a full tile that "popped ". I was fitting a V&B bathroom cabinet today. Adhesive is 3 days old. As I tightened it all up .I could here the tile "lift off" .very easy for me to re do etc .
But would have expected the adhesive to be good in that time ?
Mapei Adesilix P9 . Will remove basin unit tomorrow . Then have a look. Client need to check heights etc .
Cheers for advice. I seem to get very good help here .
Something is very amiss, because if I'm not mistaken that adhesive is a rapid set! No way they should pop off after 3 days.
Give us some photos of the wall and the back of the tile... Will know better then.
In their spec sheet it does say the bed should be about 5mm I am using a 10mm trowel. wonder if the extra 2-3 mm when bedded is the issue ?
What size were the tiles? Large format and limits of the adhesive as you say 5mm max bed recommended has probably contributed to it.
LJD,
LJD,
LJD,
LJD,
