C
Chris101
Can the uncoupler be put down on Wet Under floor heating?Well that would have at least taken the issues of the screed cracking and not being 100% dry away...
Discuss Hollow Sounds and Space under edge of tiles? in the Canada Tile Advice area at TilersForums.com.
Builders left for the day so went to check how they got on.That's good you putting Dural ci mat , but make sure his fixing will be ok .
Not to a tilerBuilders left for the day so went to check how they got on.
Held a 1meter spirit level against some areas of the floor that had the Dural put down and there are still some areas that are uneven - 2mm-3mm.
Can this be an issue?
Reply to Hollow Sounds and Space under edge of tiles? in the Canada Tile Advice area at TilersForums.com
