mdj101
I used tape and ran it along the edges of the mat
so if you saw the problem why did you then go ahead and fix the mats and the cover with laytex??? the gap between the wires should be 70mm all over if you had any doubt you should have returned the and used another supplier of heating mat. if you tile over these and you the get a hot spot of 2 sq mtrs what then?? it will prob be a little bit warmer at that point. but will you put up with it or make a fuss :mad2:
