purereason
Hi All, I’m about to start tiling my bathroom and would really appreciate some help. I’ve spent some time looking through the site, which has been very useful, but I’d be grateful for advice on the following issues.
Using -
20cm by 20cm tumbled travertine on the floor.
10cm by 10cm tumbled travertine on the walls.
Mapei Keraflex
Mapei Ultracolour plus Jasmine
The present flooring is chipboard and I intend to use 10mm Marmox as a foundation for the UFHeating mats.
Would it be advisable to use a SLC over the UFH or could I use a weaker mix of the Mapei Keraflex to cover the mat prior to tiling?
Half the wall is currently painted plasterboard with no skim and just a layer of white undercoat, then a standard bathroom paint over the top. I’ve tested the adhesion of the paint using some tape and found it came away easily exposing the undercoat and the paper of the board in some places.
I intend to sand away the existing paint but what primer would be best in this situation?
The other half of the wall is currently tiled as we are replacing a small shower cubicle with a bath and tiling along the entire back wall. I presume the original tiling was done at the time the house was built (about 12 years ago) and I think they have tiled directly onto the plasterboard.
Would removal of these tiles be the best approach, if so, what primer would I need to use over the area afterwards?
If removing appears too difficult without damaging the plasterboard then what would my next option be?
Thanks for your help
Simon
Using -
Mapei Keraflex
Simon
