Grouting Sandstone
I always use sand and cement on most sandstone a lot cheaper and better finish also I find it much easier 😛ete
Is this the Bradstone sandstone? You'll deffo need at least 2 coats of sealer prior to grouting and don't let the grout hang around too long on the tile surface. Work small areas at a time and it'll become a faster job.
Good luck.
It is the Bradstone sandstone. I'm actually applying two coats sealer prior to fixing and I think it'll take at least another two.
Todays update: By simply putting a slither some adhesive close to the joint and closing the tile up most of the joint has filled up. If needed a quick wipe with the sponge to keep things clean and the grouting should be a lot easier. Thanks to Dave for a bit of inspiration. It seems so obvious now.
I took delivery of a new DeWalt24000 yesterday after giving up on the Vitrex bridge saw. Wow!!! what a difference. Cuts the big slabs no probs. I could go on for ages on how impressed I am with it ....maybe on another post.
Thanks to all for advice.
Make sure you rake the joints out some , so grout can get a good hold.:thumbsup:
Another Dewalt owner..:thumbsup::thumbsup::welcome:
SNAP
Incredible machine, although has really struggled with Keope porcelain today:thumbsdown:
Sounds very similar to my London basement job, they will eat the grout but I used a deeper trowel as Dave suggested and this helped a lot.
:thumbsup:
hi im on a job at the mo with 900-600 sandstone ,and yes lots of sealer ,4 coats so far ,then grout and one after , its going to eat the grout i can see it coming :thumbsup:
Customer had already specified the grout so I have priced it into the job ok. But I know what you mean.
Grouting Sandstone
SandyFloor,
rbtiling,
SandyFloor,
rbtiling,
