Grey Mapei grout gone patchy
DukeofYork
Hi
We recently tiled our kitchen floor with porcelain tiles. We used Mapei ultracolour grout which is supposed to be dark grey but has dried with large white patches?
Can anyone help? It looks horrendous and our new kitchen is due to be fitted in less than a fortnight 🙁
The ratios of grout to water have to be spot on, and with a darker grout is not to have too wetter sponge when cleaning down.
New threads on same subject are always welcome as each job has it's own take..
I didn't see the other thread... but a number of things contribute to what you have.
This can be over wetting of the grout when washing off and also washing off to soon before allowing the grout to set up... if you leave dirty water in the grout lines that contain polymers from the grout then this will dry lighter...
A remedy for what you have is to clean the joints with a cement residue remover that will also remove polymers.. then follow the directions and clean the joints aided with a scotch pad.. this should bring the joints back up.. but and this is a but!.. this depends if the grout was mixed properly to get an even pigment distribution..
have a read of this as well... http://www.tilersforums.com/tile-ad...on/25037-mapei-ultra-colour-plus-how-use.html
Thanks. Think they were spot on with the measurements. Suspect it is related to the cleaning
Any ideas on how to rectify it other than a regrout?
DukeofYork,
Gazzer,
DukeofYork,
Gazzer,
