Discuss Fixing mirrored tiles, adhesive options in the Tile Adhesive / Grout Advice area at TilersForums.com.
Wishiwasatoptiler
1,108
Northeast
Hi
Looked at a job where the customer wants mirrored tiles within the field of other tiles, 300x300 size.
About 2mm thick.
Any adhesive options would be great, the background will be strapped, plasterboard walls.
Cheers
Wishiwasatoptiler
1,108
Northeast
So i have totally over thought it then Julian...
Lol.
My plan will be to build up the background behind the mirror with addy so the mirror will be flush with the other tiles. So this tubed sticky will be great.
Its good to see you back, havent seen you on here in a long while:thumbsup:
J Sid
Lol.
simple and straightforward is sometimes best.
I'm good thanks, and good to be back and seeing old faces
Kyle Knowles
1,108
Widnes
Got a funny mirror story a mate of mine the guy who I did the sage green metro in the fancy pattern the pix on here fixed a mirror with silicone and used the dick and balls method of applying the silicone and a couple months later it's ate through the backing and the customer had a lovely big Willie in the mirror lol
Spare Tool
Would need something like Webber set plus and ad250 for fixing mirror tiles with adhesive, whatever you do don't use a standard set without additive straight onto the glass, it will not stick... I know :(
Think the above is the best idea..stick tiles onto a 4mm backerboard with mirror adhesive then pack out to depth you need with ady.
Reply to Fixing mirrored tiles, adhesive options in the Tile Adhesive / Grout Advice area at TilersForums.com
  • Poll
