dot and dabbing platerboard on breeze block
shogun rua
Hi,
Would there be any problems or anything I should know, I want to dot and dab about 2sqm plasterboard onto breeze block before Tiling, the tiles are ceramics.
Cheers
Paul
prime if old block which has had plaster knocked off,or if its a high suction block,like a thermalite,prime with sbr
There should be no need to prime any blocks, if there dusty dampen the wall area with water where your dabs of adhesive are going....don't use pva if you decide to prime..
12.5mm is usually the norm for walls....If you do decide to use 9.5mm then add alot of extra dabs of dry wall adhesive..
if i use the 12.5mm it wont leave me much room to get the walls flush as there are already tiles above so would the 9.5 be ok if i add loads of pb addy?
coming from a plasterer thats weird whitebeam,ive always primed internal blockwork(if its old and dusty).
everything whats said on this forum about priming ect ect before tiling,surely the weight of plasterboard on dusty blockwork would be a issue,just saying,not bitching mate :smilewinkgrin:
I did the Dri Walling course at Brittish Gypsum and was taught only to wet/dampen dusty and high suction areas that were about to sheeted using the dot n dab method with Dri Wall adhesive.....
Created on iPhone.....
know what you are saying,but i did a 4 1/2 year apprenticeship trained by very experienced plasterers(with probably over 300y experience between them) ,always got told to prime dusty walls with PVA,internally and use exterior PVA on exterior rendering,each to his own i suppose :thumbsup:
(oh,and pva in the eighties was the plasterers dream,and i gotta be honest,never have i had a fall of in nearly 30 years of using it for plastering,even when ive used it for tiling,in the early years,never had a fall off,i would not use it for tiling now,knowing what i know)
Tags Tags
block usa
shogun rua,
widler,
shogun rua,
widler,
