Bigsasquatch
Hi,
Laid my first tiles over floorboards last weekend using DITRA, but I am worried I may have made a few mistakes.....
a) Firstly made sure that boards were level , clean and solidly screwed down, lightly washed with pva and allowed to dry completely.
b) Was given some adhesive along with the DITRA, which could be used wet, or as a contact type adhesive - applied to both boards and DITRA backing and then allowed to go tacky before pressing down firmly. Should I have laid the DITRA into wet adhesive for a better bond ?
c) My main issue is that I am worried I used the wrong kind of adhesive. I went for Evo-Stick Tile-a-Floor flexible adhesive/grout for laying on wooden floors ( ready mixed version ). I am assuming that the ready mixed version cures in Air ( i.e. not a chemical cure ), and whats worrying me is that having laid on top of DITRA , once the grout lines cure, there is going to be no permeation of air or loss of moisture from the adhesive under the tile, so it wont cure.............should I have used a different adhesive ?
In addition, I may have laid the adhesive slightly too thick, but without leaving it to cure. Difficult to know what will happen.....do I pull it up and start again ?
Cheers
BIG S
Cheers
BIG S
