Thought I would update this thread.
The D24000 has been outstanding.
I'm just in the middle of a travertine bathroom, and this is making my life so easy.
I especially like putting a slight bevel on the edges of the corner joints.
Looks so neat and the customer loves it.
When I first got the D24000, I had just come from a QEP overhead bridge saw.
"L" cuts were easy, as there was no "arm" to get in the way.
I quickly came unstuck with the larger tiles.
Certain "L" cuts would foul the arm, and I had to resort to turning the tile over.
This brought it's own problems, as I couldn't see the cut line on the tiles face.
I did find a solution (that I'm sure most on here know any way), but I thought I would post in case anybody else was struggling!
Cut as much as the arm will allow.
The D24000 has a plunge cut facility. All that was needed was to lift the cutting wheel, turn the tile around and then plunge back into the "cut line".
You then cut "backwards" if that makes sense? You use the other side of the wheel to cut.
Either way, it makes "L" cuts to large tiles a doddle and accurate again...
