Dewalt D24000 hints / tips and accessories thread
we are in scotland Neil and i cant get pic's on at home very easily , so there is no chance here!! it's the bolt that run's through the wheel with a nut on the end that has sheard off
gooner
The part you need will cost £8.79 inc VAT (if not covered by warranty or you just want no hassle)
See my link on post #20
"160 - SHAFT
BDE-612745-00"
:thumbsup:
Any one tried the tyrolit hydrostress TTE250 wet cutter ?
I had a look at one of those before buying the D24000.
Apart from it being more money, i didn't see any advantage it had over the D24000.
Now the same cannot be said of the Montolit tornado.
It looks absolutely brilliant.
Build quality looks excellent. It has several extra features not present of the D24000.
I like the built in laser. The LED angle indicator. The stand looks substantial and has wheels.
Even the water flow can be controlled at the wheel.
The water management doesn't look as good, but that may not be important to some.
The biggest stumbling block is the price. The extra features are not worth hundreds of extra pounds to me.
I can put a laser no the D24000 for £10, and a better water valve for another £5.
Maybe if i was a full time tiler then i might be able to justify the extra money.
At the end of the day.
The D24000 has all the same important features and spare parts are readily available.
The D24000 has the largest support network available, meaning servicing/repairs can be done just about anywhere.
This does count for something, as lost days waiting for spares can cost more than the machine itself.
Hoping to add a QEP laser tomorrow.
I think i have found a way to attach it without altering/drilling the saw housing.
There is a small plate that holds the water pipe at the front-left of the wheel house.
I'm hoping i can use that screw/plate to hold my lasers bracket.
It will simply be a matter of unscrewing the screw, adding my bracket and re-screwing.
I found a bath "wall bracket" that looks like it will be ideal.
It is already bent 90', but with a small u bend in it.
This will allow a little vibration/movement and make adjusting it easier.
I'm not sure how rust resistant it will be, but if it works i have a few spare brackets that i could get rust proofed.
I will post back tomorrow with pictures...
thanks ful,a the wheel and the nut and broken shaft are on my bed side table in the digs until i get home!! as i said the the runner table go's in and out ok, the surround tiles turned up today and i managed to get the fork-lift driver to get them right -in to the building today
look forward to piccies although I cant see it being much use and a pain to keep accurate.
yes well ill have to see!!, there are three wheels under each side of the table ,and i am hoping that like the song there are three wheels on my wagon that i can keep rolling along!!
fulabeer,
fulabeer,
