Cutting Porcelain tiles
A
ap222
Hello all, I'm about to tile my bathroom with 670mm by 350mm glazed ( smooth) porcelain tiles.
Just deciding on which type of tile cutter to go for.
Was thinking about the following cutters:
1- QEP/Vitrex manual pro700 cutter which comes with a 22mm titanium coated tungsten carbide 22mm wheel.
2- Vitrex Versitile power pro 900 Diamond wet saw.
Has anyone had any experience with any of the above?
I am more inclined towards the manual cutter, as the tiles are smooth, but having said that I'm not sure if the carbide scoring wheel can cut the tiles.
Any guidance appreciated.
Many thanks
hi a big sigma cutter will scribe and snap them nice with no problems at all been in the industry for 29 years hope this helps cheers
Thanks for the reply guys, much appreciated
Martry, I'LL look into the sigma cutter, as most of my cuts are going to be straight. I was just concerned that a manual tile cutter may not cut cleanly, i.e leave jaggered edges. Does the sigma have a diamond cutting blade?
I can take reassurance from you as you've been in it for 29 years:thumbsup:
regards
sigms cuttiers only work on scribe n snap what i use for nonn straight cuts is a dewalt grinder with a good porcelain blade the reason i use dewalt is they tend to have more rpm which means the grinder runs alot quicker than most grinders as inturn cut nicer and on the scribed edge of tile a bit of wet and dry will fix the edge i have big wet saws but with porc u rarely need anything else ihope this has helped u good luck most of all dont panic cheers
I've a wide range of cutters and my first thoughts for a smooth straight accurate cut with porcelain would be to try the tile on a manual Rubi TX700n
Kev
Hi AP
I have both the 750 and the 900, firstly the vitrex 750, I changed the blade to a marcrist and have cut 10mm porcelain with it. Nice saw for under £100. The arber on the 750 is reversable 19mm or 22mm, I tend to use this one a lot more than the 900.
The Vitrex 900 is very heavy (proberbly the reason I tend to leave it in the garage)
the arber on the 900 is 22mm I did change the blade to a marcrist as well, to do so requires a 25.4 to 22mm ruducing shime ( If you check the other Vitrex thread there is a link on where to buy one)
I did have a problem of chiping on the off cut of tile, but was informed by one the other members on here that it was proberbly the fence being out of square to the blade.
Is this a job you are doing for yourself?
Yes, just completed a total renovation of my Bathroom, including a wet floor, ready for tiling.
I'm just on the look out for a decent porcelain dry cutter, Sigma is well out of my reach!
I initially thought to go for the Vitrex 700, but having email vitrex, the've advised me to go for their wet cutter instead, cos its better at cutting porcelain. I'm not too sure...
changing the vitrex blade to marcrist is a handy tip.
My tiles are 12mm thick, and now trying to stretch the budget and considering the rubi tx-700-N or a Montolit Masterpiuma 75. I want to the job properly, and I have read a lot of different opinions on which tile cutter is good.
ap222,
Scott,
ap222,
Scott,
