Buzz365
I think I chose the worst flipping size tile I could have done… or is there a way? Darned if I can see it…
Tiles for the walls are 400mm L x 150 H to be laid horizontal, half-bond. Thought I would start by centring the window width and height and see how things would work. First issue, 3 tiles wide with 2mm spacers leaves slivers up each side of the window. Window size is 1190w x 1400h. The window is offset slightly. Window wall is 760w to the left, window 1190w, 730 to the right. I am I right in thinking you would normally centre the window? Or, will I have to settle with centring the wall? Will it look ok?
