Discuss ***Brand new 2018 HardieBacker installation guide*** in the Canada Tile Advice area at TilersForums.com.
Points
408
Huddersfield
Here we have the brand new installation guide for HardieBacker tile backerboard.
Updates include;
  • Now holds 200kg/m2, THE strongest board on the market
  • Only 12 x screws per 6mm board for floor installation, a -70% drop
  • Passes the impact test (ETAG003), even on stud centres up to 600mm (12mm board)
  • Overboarding plasterboard and or skim, guide on installation
We are the UK's number backerboard. If you have any questions please don't hesitate to contact me.
Luke
  • 2018 HardieBacker Install Guide.pdf
Dumbo
Updates include;
Luke
Thank you
Points
408
Huddersfield
If you look at our new guide (attached) on page 8 it shows our masonry wall installation. If skimmed the same rules apply you just need to use a longer screw. We require a minimum of 50mm of the fixing into the masonry. Just increase the screw length based on the thickness of skim.
Hope this helps!
On one
Much as I use Hardiebacker 250 to overboard floorboards quite regularly,no way in hell would trust just 12 screws to get the board secured and flat to the floor.
It might work in laboratory conditions but unfortunately I work in the real world.
Points
408
Huddersfield
We tested it with the robinson wheel, basically you add weight as the wheel goes over a floor until failure. The install with 12 x screws performed just as well as 39. We say its the minimum, more is always better but 12 we will warrant as long as our install guide is followed
Reply to ***Brand new 2018 HardieBacker installation guide*** in the Canada Tile Advice area at TilersForums.com
