Currently reading:
***Brand new 2018 HardieBacker installation guide***
Discuss ***Brand new 2018 HardieBacker installation guide*** in the Canada Tile Advice area at TilersForums.com.
Here we have the brand new installation guide for HardieBacker tile backerboard.
Updates include;
  • Now holds 200kg/m2, THE strongest board on the market
  • Only 12 x screws per 6mm board for floor installation, a -70% drop
  • Passes the impact test (ETAG003), even on stud centres up to 600mm (12mm board)
  • Overboarding plasterboard and or skim, guide on installation
We are the UK's number backerboard. If you have any questions please don't hesitate to contact me.
Luke
  • 2018 HardieBacker Install Guide.pdf
Updates include;
Luke
Thank you
If you look at our new guide (attached) on page 8 it shows our masonry wall installation. If skimmed the same rules apply you just need to use a longer screw. We require a minimum of 50mm of the fixing into the masonry. Just increase the screw length based on the thickness of skim.
Hope this helps!
Much as I use Hardiebacker 250 to overboard floorboards quite regularly,no way in hell would trust just 12 screws to get the board secured and flat to the floor.
It might work in laboratory conditions but unfortunately I work in the real world.
We tested it with the robinson wheel, basically you add weight as the wheel goes over a floor until failure. The install with 12 x screws performed just as well as 39. We say its the minimum, more is always better but 12 we will warrant as long as our install guide is followed
On one
The thing is,you will get raggy @rsed builders putting 12 screws in and say ''it's ready to tile'' and definitely won't be
Like any product we have installation instructions. If they are adhered to the product works no problem with the 12 x screws. But there must also be adhesive under the board, alkaline resistant tape, the boards staggered, 5mm gap around the room perimeter and most importantly the substrate is solid.
The drop to 12 x screws is designed to speed up and make the install more cost effective. Nothing wrong with putting more in of course. The markings (circles) are remaining on the board.
You really need to clarify the tile or stone fixing method though.
A simple reference to BS5385 would cover you as a company.
The first time some moron spot fixes 20mm marble to Hardibacker and it falls off destroying something or someone - you have a potential problem because "it holds 200kg p/sqm".
Our products are tested beyond the required capability. For example if you search our social media we have images showing 200kg of weight on only a 300mmx300mm plate. The weights are the equivalent of over 2 metric ton being held on a board.
Now if someone were to spot fix then as with any product you could have an issue. No real tiler spot fixes. Anyone who does is asking for trouble.
Kerdi board, honestly say 98% of the quotes I do wouldn’t accept price of them for prep work!
There are plenty of alternatives just as good at fraction of cost.
There are. I used a pallet of HB this week for flooring.
I still would never use it on walls though.
Some customers just want to spend silly money on "the best".
So let them!
As long as the substrate is solid in theory shouldn't be a problem. We now only ask for 12 x fixings too on 6mm on the floor. What might be better is us just popping along to have a look if that would suit Simon?
We can usually come up with a work around/spec to most installs! We hate to say it cannot be done.
Reply to ***Brand new 2018 HardieBacker installation guide*** in the Canada Tile Advice area at TilersForums.com
