- Reaction score
- 21
When calculating levels what bed thickness to you allow for when laying 60cmx60cm 10mm porc.?
Would that assume a 1/2" x 1/2" notched trowel?
Discuss bed thickness for 60cm x 60cm porc. in the Canada Tile Advice area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
you need 13 / 14mm max, with teeth 10mmif you explain the size 1/2 "x 1/2",
I tell you how many mm you need.....
sei in italia e usi i pollici?
attento che ti sparano.
è lo stesso.Grazie Antonio. Ho 57 anni, ho visuto quasi tutto la vita nel UK, si che uso pollici!
Meglio cazzuola denti 12x12 o 10x10 con una piastrella 600x600?
pregoGrazie
Reply to bed thickness for 60cm x 60cm porc. in the Canada Tile Advice area at TilersForums.com
