Discuss bed thickness for 60cm x 60cm porc. in the Canada Tile Advice area at TilersForums.com.
White Room
Make sure you back skim the tiles as well depending how flat your existing floor is.
Not sure if I phrased the question quite right. What I would like to know is the rule of thumb for overall thickness of tile and adhesive when laying 600x600x10mm porc. tiles. ie how thick is the adhesive once the tile is bedded? And what size notched trowel would that assume?
Italy
if you explain the size 1/2 "x 1/2",
I tell you how many mm you need.....
sei in italia e usi i pollici?
attento che ti sparano. ;)
Italy
you need 13 / 14mm max, with teeth 10mm
calculating that you live in Italy .....
also 15mm;)
Reply to bed thickness for 60cm x 60cm porc. in the Canada Tile Advice area at TilersForums.com
Lowpaul22
