Aquaboard
Hi all, I'm installing a new shower in a stud work enclosure. I have 900x1200 sheets and looking at my shower which is 1000x1000 it seems sensible to fit the sheets long edge horizontal.
My questions are:
Do I need extra horizontal nogins where the boards are butted together horizontally? I don't see the need but thought I would ask? (I planned to join the board edges with no nails to give a firm waterproof joint.)
Also last time I did a shower cubicle like this I used both aquaboard and a tanking kit, two kits actually, do I need to tank when its aquaboard?
Thanks if you can advise.
Paul.
Is this Knauf Aquapanel?
If it is then it’s not necessary to add noggings as you should use their sealant between board joints and stagger the boards and tape them before tiling.
Aquapanel is not waterproof, only resistant so I would recommend tanking over the top this will give you a really good base to tile over.
But if it was me I would just use plasterboard and tank that, much cheaper and perfectly adequate in domestic showers with trays. IMHO.
I didn't know they had a special sealant so thank you for that. Sounds like I need to look at tanking kitsxagain, they were £50 each in 2010!
Cheers.
Aquaboard
Tanking and Wetrooms
Tags Tags
None
Luggsey,
Luggsey,
Luggsey,
Luggsey,
