Discuss 22mm No More Ply in the DIY Tiling Advice area at TilersForums.com
The Wetroom Store - TilersForums.com Sponsor
This official sponsor may provide discounts for members
ajkzrr
Exeter
What member type are you?
DIY Wall and Floor Tiler
Hi,
I'm installing aluminum spreader plate under floor heating between joists (1930s house), and I'm thinking of using 22mm No More Ply over the joists, then tiles.
What do you think about this setup? Is that better than ply plus a thinner backer board? Will I still get enough heat transfer through?
Thanks in advance!
TileFix Direct
jcrtiling
Reactions
4,617 57 1
Salisbury
Professional Wall and Floor Tiler
You will get better heat transfer through nmp than ply . I don't know if they still do it but knauff brio I was told by knauff thermally transparent . I think this means good conductivity
Reactions
57
Southampton
Marmox used to do a board designed to go on top of UFH, different to the foam insulation board they do obviously.
F
Flintstone
The 22mm no more ply is the perfect way to deal with these ufh systems.
Reply to 22mm No More Ply in the DIY Tiling Advice area at TilersForums.com
Mapei Tile Adhesive - Official forum sponsor
Click here to support the forum/remove ads
Use TilersForums.com to find Tiling Jobs or your Local Tilers for free. Get tiling tools at the best prices via the forum.
