Discuss 1mm cut off disc other uses in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
Used it on a splashback today and was pleasantly surprisedI have once before but the amount of debris 'fling off' was unbearable!
I suppose it depends how it's used, i have seen metal blades explodeSeen one of them blades explode and big chunk went into tradesmen arm, would suggest never trying on any ceramics!
Just chucked out a diamond blade because I noticed it had a fracture . Next step if I hadn't flying metal .I suppose it depends how it's used, i have seen metal blades explode
you would expect it to be fit for purpose.
It's not actually that cut and dry, I don't suppose. Like porcelain, there are different grades.Some company's no dought can be a little economical with the truth, if it's no good for ceramics then perhaps someone should tell them.
Reply to 1mm cut off disc other uses in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
