Discuss 1mm cut off disc other uses in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
Albert
1,253
Gateshead NE8, UK
I use these for metal trim.Any one used them for ceramics?
Blunt Tool
Seen one of them blades explode and big chunk went into tradesmen arm, would suggest never trying on any ceramics!
Bond
518
Highland
Some company's no dought can be a little economical with the truth, if it's no good for ceramics then perhaps someone should tell them.
It's not actually that cut and dry, I don't suppose. Like porcelain, there are different grades.
And all porcelain blades behave differently with different grades of porcelain.
Same could be said of ceramics.
So if what they tested their blade on cut with an acceptable level of success, then from a marketing point of view, they can put ceramic on their blade.
Pretty much in the same way Hardie state their boards are impervious to water.
If you take the word impervious at its primary explanation then it's a blatent lie.
If you put in to the context of its secondary meaning, then Hardie, is indeed impervious to water.
But with a professional, common sense should warn you that a cutting blade could not possible as successful with steel as it is with ceramic. It just couldn't be. But if you're a diy'er, then the performance of the blade isn't probably so important, so therefore they may well be more accepting of a low quality cut.
Reply to 1mm cut off disc other uses in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
  • Article
123 Year Old Johnson Tiles Factory to Close Down Causing 110 Job Losses 123 Year Old Johnson...
Hi all. As title suggests. Used to use this forum a while back but seems my account was deleted...
  • Poll
