Discuss Waterproofing options for new shower room in the Tanking and Wetrooms area at TilersForums.com.
93
England
Yes. I am thinking - self-love over the mat on the flat part. No leveller on the slope and just make up the height with thinset..?
93
England
No… the floor is flat, the shower area is already sloped (a wedi riolito neo tray with a linear drain up against the wall).
I am putting a heating mat everywhere, including the shower area. And ideally I will bed it in a thin layer of self leveller. But I don’t want to do that on the shower area because I don’t want to level the slope!
I think the answer is: use self leveller on the flat floor (not to level, just to cover the heating mat prior to tiling) - and don’t use leveller on the tray, just make up the height with thinset. Ideally I don’t want a junction between the leveller and something else -beneath the tiles - but I can’t see a better way.
Someone must have put a mat on one of these trays….?!
93
England
Thank you. I already have the mat - but perhaps the answer is to embed in thinset and cover with membrane (wedi do a membrane too), so I have a flat and even surface to tile on. And I can use the same technique on the tray as I am not bothering with leveller.
93
England
In the end I put my Big Boy pants on, mixed up some rapid setting leveller, waited 5 minutes, poured it, and raked it back up the slope a few times till I was happy it had set.
I have so many layers going on already I decided against membrane. The mat and leveller are on 50mm wedi board so I am happy there is decoupling.
Reply to Waterproofing options for new shower room in the Tanking and Wetrooms area at TilersForums.com
  • Poll
