Discuss Setting out tiles in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi all,
Due to money constraints I am having to renovate the bathroom myself.
I am trying my best to set out the tiles before starting to avoid slithers.
I'm using metro 20×10 tiles and 2mm gap.
But no matter which way I try I end up with either a cm gap at the ceiling or a slither under the window cill.
Its difficult due to the window.
Is there any advice that might help me get started please?
You have room to build cill height up to aid datums.
Hi Dave,
Yes if I use the bath level to start I can get two tiles perfectly under cill and use the window center to get same cuts on either end.
If I raise the cill it will fix my issue yes.
But then I'll create a slither under the cill sadly
Dave
Hi Dave,
By raising the cill height ( plasterboard it ) then you won’t have as small a slither.
Reply to Setting out tiles in the DIY Tiling Forum area at TilersForums.com
Dawz84
