Discuss Stubborn cement on bricks in the The Welcome Forum area at TilersForums.com.
36
Belfast
Morning,
Just put clay brick tiles on a wall.was advised by builder to grout with sand and cement. I can't remove the dull after of cement from the brick. Tried a mortar remover but still not getting the expected colours from the brick. Any ideas
36
Belfast
Pics attached dave thanks for your help. Seems to be a white kinda dried out look stopping the brick colour come through mate.
Lou
Admin
1,473
Staffordshire
Hi and welcome to the forum.
How have you been getting on with your issue?
38
UK
You need muriatic acid (brick acid), it's strong stuff so be careful- full ppe. You can't get any mortar on brick as it'll soak in, so no cleaning with a wet sponge or anything.
The mortar remover if it's what I think is only for whilst everything is wet- which isn't much use in this scenario as you can't tell it's an issue until dry!
38
UK
Installation guide for brick slips- How to Install Brick Slips - https://www.bricktilecompany.com/news/how-to-install
423
Huddersfield
I’ve done brick-slip pointing before, and one rule is to spray and wet the slips before hand. I also injected the mortar into the joints and finished it off with a small trowel. It’s different to pointing outdoor bricks. Because they aren’t bricks. They are brick-slips. Another builder out of his depth!
Check my gallery out…
Reply to Stubborn cement on bricks in the The Welcome Forum area at TilersForums.com
