Discuss Uneven floor out by 60mm in the Canada Tile Advice area at TilersForums.com.
318
Rochdale
Hi all!
Doing a bathroom 3.9m long, the floor currently is tiled and run out from the door to the other end of the room by 60mm.
im wondering whats best practice.
ive seen you can get self level compound upto like 80mm but I’m unsure whether to use it.
the floor is having karndean vinly put down to, but obviously want my floor level for the wall tiling.
thanks in advance!!
Tony_C
518
Glasgow
Why does the floor need to be level for wall tiling? just cut your tiles to the slope with a nice chunky cut.
Assuming it's tiles of a decent size and not metro...
I'm thinking more of what the doorway would end up if you attempt to level it by that much
318
Rochdale
Thanks for adding to the post!
the flooring at the doorway is fine, it’s just the other end of the room, a 60mm slope
the tiles are 550x330 so a good size for cuts, but i think you notice the size of the cuts from the doorway to the other end of the room
Ajax123
1,213
Lincolnshire
What's the floor made of. I assume its timber in which case putting 80mm of levelling screed on could cause major issues.
318
Rochdale
this was my concern, i read on here somewhere that just a 25kg bag weighs around 52kgs 😯 (if I’m correct there)
think the only Option would be to redo the floor.
it is timber floor
CJ
1,088
Somerset
If it’s that far out, I’d be concerned.
only thing you can do is totally redo the floor. Rip up and level joists.
60mm = 102 kg a square metre
A 25kg bag weighs 25kg when its dry
Probably about 30kg wet
Ajax123
1,213
Lincolnshire
Fairly close. The usual declared dry density is 20kg for every 10mm depth that's because a 25kg bag is not fully compacted so in terms of volume it's different to 25kg of compacted laid screed. If that makes sense.
[automerge]1583313095[/automerge]
Why? My house is timber floors and all the upstairs floors run out by 50mm plus mostly running from the central supporting wall to the outside supporting wall. It's due to time and settlement and slightly wonky building. I have no clue how I would RIP out and straighten up without massive disruption and some fairly robust building work upstairs and downstairs. My house was built in 1740... some houses are just a bit wonky. Ripping out is not really a viable solution.
CJ
1,088
Somerset
Well, by the sounds of it, the poster wants a level floor. Taking up floorboards and sorting joists out isn’t THAT a major job. Better than a shed load of self level.
I'm the same as you, if it’s a old property, and the floors/walls are all over the place, then you work with what you’ve got.
widler
1,328
England
Board in 6mm cement boards , board the back area gradually up in from the centre to the back , build the rest out in slc to the front end .
Easiest job in the world
Boggs
1,118
Uk
You could lift the existing floor and add some firrings to the joists, I think this is what I would do.
60mm is a fair drop even over 4m.
318
Rochdale
Thanks for all replies!
think this is the option we’re going for, keep costs down.
the house was built in 1840, so it’s abit wonky 😄
widler
1,328
England
It’s just as good as the other options ,and a lot easier and cheaper than lifting everything and re laying joints and floor boards .
I have done it loads in many houses
258
Aberdeenshire
my effort on my wonky old house from the days pre spirit levels!! Well, strictly speaking not fully my effort. i had to lift the floor due to the old shower leaking and added the noggins, rescrewed/bolted the exisitng, replace the furthest joist, add in the second furthest since it was missing etc etc.
labour of love these old gaff's !!
Reply to Uneven floor out by 60mm in the Canada Tile Advice area at TilersForums.com
