Discuss Joining horizontal tiles to shower tray. in the Tanking and Wetrooms Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Deleted member 53212
I am retrofitting a 1200 X 760mm shower tray into an irregularly dimensioned shower room 1200mm X 1200mm X 1000mm X 780mm. The short sides are parallel and square to one long side. This leaves a roughly triangular area 1200mm long and about 30mm wide at one end and 240mm at the other which I intend to tile. The existing wall tiles sit on top of the tray with a small gap.
My problem is this: If I tile so that the tiles fit under the wall tiles I would have to butt the tiles flush with the top of the shower tray in order to get a slight fall. No problem with the wall/tile joint but how do I make the tile/showertray joint water tight? If I just use silicone sealant should the gap be as tight as possible - say 2 -3 mm or should I leave a wider gap say 10mm in order to allow a bit more flexibility in the silicone. Is one product more suitable than another? Is there a joining strip for horizontal surfaces similar to the one developed for wall/floor joints?
Another option might be to butt the tiles up to the wall tiles and run the tiles over the tray. I could use something such as Shower Seal Ultra 10 to seal the wall/tile joint but is there a trim strip that would seal the tile/tray join? Or again, would silicone be the simple answer? The tiles are 8mm.
Tile Marble Granite
Big issue there. I had a similar job back in January.
Nope
[automerge]1572797956[/automerge]
You will have to build it as a shelf, meaning the tile has to sit on top of shower tray. Proper pitched down so the water won't sit on top. Proper waterproofed with waterproof membrane, corners. I always use Schluter Kerdi corners
Thanks for that. I haven't had time to check out Schluter Kerdi website in detail but they look the business. I'll get in touch with them tomorrow. And I'll work on my second option to bring the tile over the top of the tray. I suppose it wouldn't hurt to bed the tiles on a bead of silicone on the tray and then finish it off with silicone along the edge. My only slight concern is that the edge of the tile isn't coloured and without an edging strip it could look unsightly.
Tile Marble Granite
Use a stainless steel trim for that
Reply to Joining horizontal tiles to shower tray. in the Tanking and Wetrooms Forum area at TilersForums.com
laattaana
