Discuss Split face porcelain in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Joshjupp
Got these split face porcelain tiles to do tomorrow as a feature wall would you grout these or not they aren’t being used in a wet area thanks
Tony_C
I knew that wasn't yours :D
It might look much better ungrouted and staggered as you wont have that gap at the center where 4 meet when they are stacked. A grout piping bag could make it a much easier job also. I've had a few nightmares grouting some textured splitface tiles:(
Joshjupp
I’ll see what it looks like once there installed if I have to grout them I will but wouldn’t mind not grouting them as all the tiles on the other walls are white with white grout I’d have to be seriously careful grouting them haha
Boggs
If it’s not going to get wet definitely no grout for me. :)
GoneGuy
If it’s not in a wet area but then up and stagger them, if the gaps are too big then try and use a grout colour close to the tile colour so that it won’t stand out
U
Unused Account 1
Got these split face porcelain tiles to do tomorrow as a feature wall would you grout these or not they aren’t being used in a wet area thanks View attachment 108886 View attachment 108887
Morning josh,ive done a lot of these ,i never grouted them ,as one the gaps so small and the different thickness you will struggle to get in ,i did 40 metres outside ,just sealed it 3 times ,no problem
Are they porcelain ,or slate
Joshjupp
Thanks that’s what I wanted to hear it’s only a small feature wall in a cloakroom so it will never get wet
Ive done both with these sorts of tiles and it can actually make the joints stand out more if you grout them. Dry area, no grout for me.
Reply to Split face porcelain in the Canada area at TilersForums.com
Lowpaul22
