Discuss Best way to cut 20mm porcelain in the Canada Tile Advice area at TilersForums.com.
Battipav tile cutter works wellWhat’s the best way/ blade for cutting 20mm porcelain been cutting with a 4 inch grinder it’s taking a long time with the rubi blade and getting really hot got a few hundred cuts to do
These tiles are really hard tried breaking them on my montolit it wouldn’t touch them so just ordered a 9 inch rubi tvx blade should cut through them nicelyI've just done 100's of Mt's of 20mm x1200x600.
20mm Porcelain comes in different hardness and the ones I have been doing were prity hard.
I started cutting them with a Rubi TC180 wet with a ats blade designed for 20mm Porcelain wet cutting, worked very well. Then tried an old Rubi blade dry and it cut just as well. With both methods I cut through both ends dry with a 125mm angle grinder to stop the tile splitting of.
Doing round edges and bull nosing was a monsterous job and took days
Sigma and montolit wouldn’t break these tiles just ordered a bigger dry cutting blade for 9 inch grinderI was about to ask the same question. Ive got a patio to do soon. Will they score and snap on a Sigma? I was going to try giving them a heavy score then bashing them with a mallet...
Didn't try it, think simga say it will cut 19mm
Looked at a job on Tuesday a marble patio laid by some builders had laid it upside down and dot and dabbed it then the dabs were showing through the marble so they tried cleaning with brick acid completely murdered it Most jobs in norn iron are done by gardners with still saws .
And then tilers are asked to fix them when they fall to crap
toatal destrLooked at a job on Tuesday a marble patio laid by some builders had laid it upside down and dot and dabbed it then the dabs were showing through the marble so they tried cleaning with brick acid completely murdered it
Yes been told they are really good cutters want to test one out I just bought a big battipav cutter I’m not keen on it so looking for another big cutterJust talking to albert about rubi tz it snaps 20 mm porcelain
Reply to Best way to cut 20mm porcelain in the Canada Tile Advice area at TilersForums.com
