Discuss God bless the levelling sysyem in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Andy Allen
Thought the pliers were mandatory..?
Appreciate the help, some useful tips.
Would you say it adds a lot of time on a job..?
Tony_C
They can be a little fiddly at first as the bases are quite thick but once you get going it outweighs any faff at the start you may have and then when (and if) you use them again you will fly through the next job. Also remember to leave clips in the tiles that you finish off for the day, that seems an obvious one but i can still catch myself out with it still. I place lots of obstacles over or around them to help remind the customer they are there overnight.
There is a good video on youtube of a guy adapting a multi tool grout blade for getting into snapped clips or if you didn't leave any and want to get some in. I'll try find it if anyone is interested in having a watch
widler
I never use pliers , just use your hands , much easier.
I use mostly on large tiles or planks.
I’m doing a 50m2 plank at the mo,the clips are a must imo, I think the only thing what’s slows us down is back buttering tiles now.
Once you get used to them , it’s speeds up the job without a doubt
Tony_C
Here is the video, i've watched most of his stuff, sad i know, but he has some good ones
Spare Tool
Generally unless they're just crap clips the only reason they don't snap off properly is cuz they're cacked round in addy, found running the tip of a scraper just down the edge of last tile stops this happening. Also Imo anyway its a waste of time using rapidset with clips..
Spare Tool
Last row of the day I use off cuts and stick some clips in and lightly push in wedges to keep in place for day after..
Spare Tool
Any clip can be forced into breaking off if you tighten them too much, the 2mm schmox dont bend, are strongest ive tried and excellent value for money... The only slight complaint are the bases are around 3mm thick so 10mm notch minimum but wouldn't use less than that on a floor anyway so no problem..
Reply to God bless the levelling sysyem in the Canada area at TilersForums.com
Dawz84
