Discuss Hearth Tiles have come loose in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
jimbo
I recently tiled a hearth with porcelain tiles but they have lifted.They were set onto slc built up to approx 40mm.The slc was allowed to dry and then primed.The smaller tile pieces on the front are ok .Its just the tiles on the top that have lifted.Any ideas why this would happen?
Spare Tool
How long before the fire was lit? Like with ufh the adhesive needs a couple of weeks minimum to fully cure..
What adhesive, did you backskim the tiles?
acaciaguy
I have fitted many tiles under log burners. What tiles. What adhesive. How long did slc have to dry etc. How thick are tiles
jimbo
The fire was switched on 2 days after.Maybe that's it.The primer had been dry for an hour at most.I used Tilemaster rapidset flexible adhesive.The tiles are 10mm thick and I back buttered them.Dont want to relay them if I haven't found out what caused it.
Spare Tool
Could be something as simple as that.. @Glynn from TM is on here he might have another idea?
acaciaguy
Yes could well be too hot too soon. Check with manufacturers of slc and addy re: temperatures and cure time
Reply to Hearth Tiles have come loose in the Canada area at TilersForums.com
Dawz84
