Discuss diamond blades, again in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com.
Having bought a 115mm variable speed grinder for trimming and grinding porc. tiles dry I'm having problems with chipping, even if only slight. I bought blades that seemed to be well considered on this forum but they weren't particularly expensive. What would be the best diamond blade for dry trimming porc?
Italy
I bought blades that seemed to be well considered on this forum but they weren't particularly expensive.....
what are they?
I'd rather not say. The chipping is with one particular tile, Refin chromie, and not particularly bad and it might simply be the tile rather than the blade. Or me, although in the past I have used Bosch blades without chipping on porc. As I'm in Italy, can you suggest a good blade here?
Italy
I'm just an apprentice,
I wouldn't know what to advise you
still use blades from 5 € :)
I don't think I asked for an expensive blade, just a good one to try as an alternative to the one I have.
But I don't recall seeing too many diamond blades in Italy for 5 euro.
Simon Dale
Do you cut with a wet sponge ? :)
Reply to diamond blades, again in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com
Teejay
