Discuss Underfloor heating questions in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Glued means use adhesive . As regards height it is what it is . It's function over form . After a while you won't notice the height difference and wonder what the fuss was about especially if you fix a purpose made threshold out of timber to accommodate the difference . But if your ufh doesnt work properly it will always not work properly and you won't get over that .
Dan I would bedded the insulation boards on a 6-8mm flexible adhesive bed mechanically fix the boards down then with the fitting that go with the boards which you can get from the company that supplied the board the UFH matting normal has a sticky side which isn't all the great so I would use a stable gun to hold down the matting but nowhere near the heating wire as you only what to hold it in place until you've screed over the matting with a levelling screed by doing this you with optimise the full function of your UFH , as it will distribute the heat equally all over the floor making it most cost efficient to heat
Uheat - Jake
TF Official Sponsor
If you're going onto a screed you can use the XPS Insualtion boards.
We recommend these are stuck down with a 2mm bed of adhesive. These don't need to be mechanically fixed as there's no bounce on a solid concrete floor. Mechanically fixing is only really used with Timber subfloor.
Aha yeh you meant tile adhesive :), I'm not up with the terminology!
What total build height do you think I'm looking at?
I'm also thinking of using carpet shims and thick underlay when the carpet gets replaced to make up some of the height difference to the finished tiled floor.Last thing I want is to have a proud threshold that we keep tripping over.
Uheat - Jake
TF Official Sponsor
The usual build up is around 18-20mm before tiles. You normally have the following,
2mm adhesive bed for insulation
6mm insulation
4mm heating mat
6-8 flexible slc
Thanks I've heard 25-30mm. That 5mm will make quite a difference, with the transition to the future carpeted room.10mm underlay and 12mm carpet. Ive then got 8mm to make up with carpet shims. Probably not a great finish as you'll see the slope and trip on it. Other option would be to screed the carpeted room's floor, but that will run into a small fortune I don't have.
you could possibly build up the carpeted area on the green minerals boards the use for lamnate flooring lay your underlay on that then your carpet if need be double layer it that between 7-9 mm thick or screw down 12mm marine plywood down to raise the floor up that would be cheaper the levelling screed as that come in 8 x 4 sheets
That's a similar method to the carpet shims. Im a bit weary of putting down mineral board on a concrete floor, even with a marine board in case I get damp problems.
If you've got damp problems or if you get them, then the underlay and carpet are going act like a sponge and soak it up anyway, is the concrete new
Reply to Underfloor heating questions in the Canada area at TilersForums.com
Apatel
