Discuss 1200mm polished porc in the Canada Tile Advice area at TilersForums.com.
Kyle Knowles
1,108
Widnes
I was thrown my self I'd used rubi for years setting the hight of the rail in relation to the bed was a new concept
Think about it though . With the rubi you set handle height using the cutting wheel and then there is a certain amount of personal preference. Same but different
@James De before I got my sigma a guy told me if you have your bar set that it is level with the top of the blue housing it sits in this about pretty good for a 10mm tile and to be fair he is not far off so if your tile is 12mm seet your bar 2mm above the housing and give that a go .
Waluigi
Sigma not only suggest adjusting the height for different thickness’, they also suggest different heights for varying hardness of materials. I noticed this in the instruction booklet. It was barely legible.
Bopster
563
Colchester
I’ve not bothered reading instructions lol
All I’ve done is check it for square and adjust the bar to 1mm clearance between breaker foot and tile surface
I have extra support leg yet to fit, presumably I just drill the base to suit the leg?
I’m struggling to understand what you mean here,
do you mean with the foot folded or extended?
No, you don’t need to drill any holes, they’re already there.
Bopster
563
Colchester
With the foot in the down position and the handle raised leaving the 1mm gap
In the photo I can’t see how without drilling it would fit
Reply to 1200mm polished porc in the Canada Tile Advice area at TilersForums.com
