Discuss 900x150 Porcelain Planks Spacer Size in the Canada Tile Advice area at TilersForums.com.
P
ProPrecisionTiling
Hello All,
Looking for a little bit of advice for an upcoming job...
900x150 porca planks - what spacer size would you use? 3mm, 5mm or other? Customer wanted them laid in half brick bond but have advised should go for 3/4 running bond to help avoid bowwing/lippage issues. Don't see too many 900's around here, so what spacer size would you go for?
Cheers
P
ProPrecisionTiling
Looks like 2mm is the shout - cheers lads. Never gone below 3mm on floors before, that rule a bit of amyth then?
GoneGuy
Not necessarily it’s 3mm for floor by British standards I think ( I’m sure someone will correct me ).
Plus if the tile is bevelled edge using 2mm will give an appearance of 3mm once grouted
P
ProPrecisionTiling
Yeah 3mm is BS standard and always followed that. But in your experience 2mm is more than okay as well? I see the benefit in using 2mm. I will make a decision when I get my hands on the tiles
GoneGuy
Yes 2mm is ok as long as substrate is solid etc.
I’ve even gone down to 1mm in a small area
On one
30mm for me.
Seen a few plank floors where 2mm spacers have used and it ''just didn't look right''
L
LM
2mm for me, but I do wonder if you’ve use levelling clips before? Perhaps you have but if not this job is the ideal scenario for them.
Reply to 900x150 Porcelain Planks Spacer Size in the Canada Tile Advice area at TilersForums.com
