Discuss Have they glued this down?! in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Mark Gill
Any idea what has been done, looks like they have glued them down onto the floor below, which is like a cement lyno?!
Mark Gill
Oh and I should mention the house was built in 1994, are they still likely to be asbestos?
Q
Qwerty
On closer inspection I have just noticed the plasterboard wall on the left of the photo!
You should have no problem getting that lot up
Bill
I have tiled over soft flooring many times. If it is stuck well, just use your noggin and prime it correctly and everything will be OK>
Time's Ran Out
John did you used to lay them as well?
I did a few before I almost cut my finger off with a sharp Stanley blade!!
Used to get covered in black bitumen adhesive and my tools were only good for 1 job.
Last one I did was about 1976.
If your going to have vinyl it seemed to be the best.
Reply to Have they glued this down?! in the DIY Tiling Forum area at TilersForums.com
mcgtech
