Discuss Hand held floor grinding set up in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
That's got a motor in it ? I thought it was a can that was inline that dust fell into on its way to the vac? Am I on another planet ? :D
For 25 quid, it isn't worth making one. Are the ones with a motor in just to boost the suction then I assume
L
LM
TBH I sent the wrong link at first because what you actually need is a simple seperator which you found anyway. I’m not saying you’re a tight arse ;) but I then sent you the diy link. If you watch it to the end it explains very well the benefits of using a seperator.
WetSaw
Definitely something I need to get. Although being a tight arse with plastic pots always available and pipe fittings in stock I may well lash something together.
Reply to Hand held floor grinding set up in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
