Discuss Hand held floor grinding set up in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com.
F
Flintstone
For 25 quid, it isn't worth making one. Are the ones with a motor in just to boost the suction then I assume
L
LM
TBH I sent the wrong link at first because what you actually need is a simple seperator which you found anyway. I’m not saying you’re a tight arse ;) but I then sent you the diy link. If you watch it to the end it explains very well the benefits of using a seperator.
WetSaw
Definitely something I need to get. Although being a tight arse with plastic pots always available and pipe fittings in stock I may well lash something together.
F
Flintstone
Do you find much difference between the cheap £5 grinding cups and the £40 + ones such as ats sell, £80 even for the 180mm
Q
Qwerty
Grab a few cheapies. They aren't bad to be fair. I killed my few cheapies on a s&c screed that had a huge belly in it
L
LM
Imo you’ll only be able to gauge that if you’re doing a lot of it and spending enough money on it they you’re asking the question.
judge
1,078
I've got a 9 inch grinder with a cowling attached to a single motor industrial dust extractor which I use for pretty much every floor I tile whether it's simply grinding the surface to remove latience , contaminants or taking high spots down.
Checkout a floor preperation site like pwm or surface preperation
Blunt Tool
Reply to Hand held floor grinding set up in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com
