big scratch removal - how?
frogeye
Hi folks
can anyone recommend an easy method of removing a nasty surface scratch to a couple of tiles. I was just raking out a bit of grout with one of those grout removal tools, when I slipped and put a 12" curved black scratch over 2 cream tiles - I can't be the only one who has done it?
Without going out and spending a fortune on some polishing paste can anyone suggest how I make good?
I did make some progress by using grout on a cloth which acted as a fine paste but it is hard going. Vim any good? Any hints gratefully received. What did you do?
frogeye (more suited to gardening now)
Cheers Andy
not the news I was hoping for but as a last resort I will bear it in mind.
I was grouting a small area in my kitchen when I wondered if the grout paste would have an effect. It did remove some of the line - it's more like a dotted line in places now - or was I just lucky.
As I said I can't be the first or only person to make this blunder.
frogeye
Try some vim ( or wot ever its called now ) and furniture polish mixed.....if they are a matt finish then you might have just knacked them but worth a go......
Ahh T cut - never thought of that. I think my trusty AH frogeye can spare me some.
I will try all suggestions but will get the trusty dremel out with a buffing pad on it. Consider myself the test dummy for tile scratch removal, I will report back my in depth findings. Luckily it's under the sink so I shouldn't cause too much damage
That is definitely the last time I use one of those plasplug grout removal tools. It just skipped over the grout marking the tiles - left the grout unmarked. Dremel plus cutting disc in future.
frogeye (ex tiler)
I wonder if nano scrub would work.... kev from tilinglogistics might have a majic remedy :grin:
nano scrub and a bath rubber - what are they?
Am I really the first person to do this? :yes: (surely not)
frogeye
frogeye
Nano scrub is a product made by aqua mix its a deep cleaner... has a reputation for getting stuff off tiles where most other products fail. Never used it but have heard anacdotal evidence and also seen before and after photos. Tilinglogistics will know if its likely to work. Its between £10-15 for a bottle (I think 750mm)
I would try the t-cut first before trying these expensive products from aquamix....plus there are better and cheaper products about as well.......
frogeye,
Caroline 63,
frogeye,
Caroline 63,
