Discuss Mapei proud to launch MOSAIC ADHESIVE: Manufactured in the UK. in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Mapei UK Marketing
Mapei UK launch Mosaic Adhesive; manufactured at Mapei’s West Midlands UK factory, the professional white cement based adhesive is designed for interior and exterior installations of wall and floor, glass and ceramic mosaics.
Mosaic Adhesive products - http://bit.ly/2w5dM9R has a high level of synthetic resin and special additives, as well as an extended open time and increased deformability. Additionally, as a result of being highly thixotropic Mosaic Adhesive has useful non slip properties when used on vertical surfaces.
To read the full story visit Focus on | MAPEI adhesives sealants chemical products for construction - http://bit.ly/2vnyS5p
Italy
I believe that to make mosaic,
The 5 kg bag is ok.
you always have fresh material.
and lay mosaic does not require large volumes of adhesive.
Blunt Tool
This wasn't around at the time for you tho, interesting the resin and additives, still cement based and a S1 but I've one coming up with gem mosaics mesh backed might be an option. Thought there might have been an option for bigger bag tho
I miss the old BAL mosaicfix.
It was perfect and they ruined it.
1) made it grey and icky by adding unneccessary "fibres" (because Ardex said they had to) and
2) made it Topps exclusive.
Terry the tiler
no matter what I do to prevent it, I always get lots of air bubbles when grouting mosaics. I've tried different consistencies, different grouts, different methods of applying, slow hand mixing, fast mechanical mixing...etc I still always seem to get these air pockets.
If this product guaruntees no air pockets I'm in.
Blunt Tool
Do they mean adhesive will keep drying and won't be affected by grouting, but only on walls!
Reply to Mapei proud to launch MOSAIC ADHESIVE: Manufactured in the UK. in the Adhesive and Grout area at TilersForums.com
mcgtech
