Discuss Tile grout blown, tiles easily lifted up. what's the problem? in the Tile Adhesive / Grout Advice area at TilersForums.com.
36
London
Hi,
I have numerous problems with tiles laid about four months ago.
Problems include:Grout coming up; tiles moving up and down; hollow sound when you step on a tile.
I lifted a tile. It came up very easily - in one sharp blow of a hammer! Underneath is tons of grey stuff that has cracked - presumably the glue.
What has happened? Has the glue not worked ?
What should i do to rectify this problem?
Thank you for any advice.
Brendan
Blunt Tool
Looks like the adhesive was already too dry as it has not bonded onto tile or ply. Best to take up floor, if tiles all come up like that they can be used again just clean edges. Give sub floor a good coat of SBR bonding, and a bag of slow set flexible S1 cement based adhesive ( Mapei etc ) from your local tile shop. Grout with a flexible grout
Bond
518
Highland
As noted above. Adhesive failure! may also have dampness issues. Is this a ground floor entrance?, if so, I would check the structural integrity of the floor joists and for potential sub-floor dampness problems. Only way to know is ,take up the tiles, etc and have the area inspected.
Time's Ran Out
Your not having much luck are you.
That's 2 threads started both with tiles coming up. This hallway and a bathroom.
I'd get the tiler back!
Glynn
473
LEYLAND
It could be that the adhesive has not been serrated out evenly and the tile not back buttered, also the adhesive looks dark like it is still damp. Could there be damp there? Is there any UFH?
36
London
Many thanks for your replies.
You could be correct about the possibility of damp. We are having to install a damp course into the adjacent walls in the front hallway. Dampness runs half way up the walls.
Saying that, the joists and noggins weren’t damp when the tiles were installed.
Plus, the builder used cheap plywood. Some of it (6mm) went onto floor boards. The remainder was 18mm ply where they were no floorboards.
Is it just damp that would cause the adhesive not to bond to the tile or ply?
Some recommend I don’t use plywood. Do you agree?
What does SBR bonding do (in layman’s simple terms!)?
Reply to Tile grout blown, tiles easily lifted up. what's the problem? in the Tile Adhesive / Grout Advice area at TilersForums.com
