Discuss Floor Levelling small area to tile in the Canada Tile Advice area at TilersForums.com.
john56897452
Hi
I am finishing off the en suite and have about 2 - 3 sqm of floor tiles to lay. Don't want to spend out on an expensive levelling system I,ll probably not use again for such a small space so I have seen the screw down type (orange topped looks like you add at every intersection of tiles), and a wedge set with pliers. Which would be preferable for the job?
I know the area is small but I would like to make a good job of it if either choice above is any good?
Cheers
John.
Ttt1601
628
Abbotts Ann, Hampshire
The main thing is don't be expecting clips to do all the work for you. The prep work to make it a flat surface to Tile on, still has to be done well, the clips are there to maybe do the last 1-2 mm of adjustment AT MOST then hold the tiles until they set, make sure you have good coverage under the tiles. What size are they? Either system used properly will be absolutely fine for the job
Tilerdurden
I concur.
Poor preparation precipitates **** poor performance.
Amy more than 3mm out of tolerance then adequate measures should be taken to ensure flatness.
john56897452
Thanks,
Using 6mm hardie backer screwed to the floor so should be flat. 275 x 360mm tiles so not many to fix.
John
Tilerdurden
Thanks,
John
Should be... Have you checked with a straight edge mate. Never rest on your laurels. If the sub floor under the hardi backer is off then this will transfer. If it's timber tongue and groove you can almost bet your house on it. I'd suggest an uncoupler with the installation. Just my 20 pence worth. Good luck mate :thumbsup:
Tilerdurden
Uncoupling membrane. Bal do one called rapid mat or there's schluter systems ditramat. Both good quality. If you're concerned on finished floor heights bal only comes up 1mm thick whereas Schluter will add 3mm plus the adhesive which will add around another 1mm They help to negate any movement in your subfloor which can transfer to top layer of tile causing stress at grout lines and cracking of tiles. They won't cover for vertical deflection but help with lateral movement. To make sure there's no vertical movement ensure your subfloor is screwed down securely. A good test is to jump up and down on the floor to make sure theres no spring in it. These should be installed with problematic floors. Tbh I use them in pretty much every installation I do. Belt and braces every time. You can pick them up at a tile outlet. Find an outlet that sells it by the metre as it comes in 30m rolls. Which would be a tad more than required. Put it down with a 4mm notch trowel and can be tiled over immediately.
john56897452
Cheers for this mate. Would this go under the hardibacker onto the wooden floor or replace the hardiebacker...........probably a stupid question.
Reply to Floor Levelling small area to tile in the Canada Tile Advice area at TilersForums.com
  • Poll
