Discuss Advice - Tiling on concrete with no dpm in the Canada Tile Advice area at TilersForums.com.
william underhill
Hi, just after some advice about my kitchen floor which I'm currently looking at renovating.
I did have quarry tiles down on the floor and I have now taken these up and there is a concrete slab underneath but there's no dpm under the concrete due to the age of the property.
Just want to check that I'm going the right way about things with my current plan...
Liquid DPM onto the concrete slab, then lay insulation above this and then lay electric mat underfloor heating on top of this. Then lay a self leveller on top of this before tiling over that.
Anyone aware of any issues that I'll have by doing this or any other advice would be welcome. Thanks.
Bond
518
Highland
Sounds like a good specification to me. The potential issue that came to mind is, if, the concrete floor is absorbing moisture from Sub-soil for instance, ( also check for the presence of mineral ground salts to the slab), you may as a result of the proposed work.be transferring moisture/more moisture to the wall structure. As it's an old property, might be worth checking if you have an adequate damp proof course in the walls and its position in relation to the abutting concrete slab. Just a thought.
Ajax123
1,213
Lincolnshire
you need to think about where the damp is going to go. Particularly if your house has had an injection DPM in the walls. Liquid DPM's for floors are not designed to stop rising damp. they are for suppression of residual moisture. Rather than a liquid DPM you might be better using something that will continue to allow moisture out of the concrete e.g. Ditra or similar. then you need to think about the walls as I said. If you stop the floor from breathing you run the risk of the base of the walls becoming very damp and if they are DPM's integrally as well you are asking for trouble. Other than that it sounds fine... :)
Ajax123
1,213
Lincolnshire
Doh...should have read the whole thread ... just repeated what Bond said... still best to be told twice than not at all I guess...
Reply to Advice - Tiling on concrete with no dpm in the Canada Tile Advice area at TilersForums.com
