Discuss 22mm ply onto joists, ufh, which board to use and why? in the Canada Tile Advice area at TilersForums.com.
Scott HAZARD
Hi all, been browsing through the forum trying to find a definitive answer. I'm in the process of qouting for a 33m2 floor. The floor is not ready yet, but it will be 22mm wbp plywood primed on all surface and then down directly on to the joists, noggins will be added and bricks built up under the joists to give added support also.
UFH will be installed, now I'm split on using 6mm no more ply or 6mm jackonboard beforehand. As far as i understand it, no more ply installed correctly will give added strength comparable to 18mm ply, which is great. But I feel jackonboard, will not give us much structural strength but much better heat and sound insulation, both will then have self leveller over the top before being tiled.
The tiles are porcelain wood effect look, therefore I believe an uncoupling membrane is not necessary as the both boards are dimensionally stable?
What would you do and why?
Scott HAZARD
No, what an awesome product, glad I asked the question and got your answer already! have you used the product yourself?
J Sid
not the 22mm , no, but I would if I was ever asked 'how should I prepare the floor for you ' by a builder ;)
K
Kevbos
I always think you need 18mm over joists then another 18mm .this makes floor rigid and no bounce .lay the ufh. Self level then use ditra or equivalent .I always coat over the decoupling membrane with adhesive too to fill holes properly
R
Rizzle from the Portizzle
the first part is right but first layer of ply should be 12.5 mm screwed down then coated with wood glue then cross plied with anther layer of 12.5mm ply then screwed down when the glue drys between them it will have the strongest bond with no ruining
joints and take out any flex .next its better to go over with 6 mm insulation board for electric ufh then self level with firba reinforced floor leveler then tile
K
Kevbos
That's not what I was taught by a tta founder
My builder.com says 18mm then 12mm
Weber say over board with 9mm ply if no bounce
Dan
Admin
1,318
Staffordshire, UK
Dude, try not to double and triple post! I keep needing to merge all your posts. Edit your original post and add to it, or wait until somebody else replies before replying again. :)
Scott HAZARD
Thanks for the replies guys, although slightly conflicting lol, I've suggested the hardifloor and tbh am quite keen to give the product a go.
On another note Ufh, biggest matt sold I can find at the moment is 12m2 roll. I havent installed anything bigger than this, I'm guessing its possible to combine matts? meaning you can run them all to one thermostat or something?
Reply to 22mm ply onto joists, ufh, which board to use and why? in the Canada Tile Advice area at TilersForums.com
