Advice for new electric cutter
Grime
Hey All - I've just recently started in the trade and on a recent job I used my brand new Rubi ND-180 wet wheel and it broke after cutting 5 6mm tiles. No joke! The power just keeps cutting out, so I'm gonna take it back.
But I need something else to replace it and I'd be grateful for your advice.
I have two manual cutters (a little Rubi Star 50-N-Plus and a big Sigma 3P3M) and an angle grinder. Any suggestions for an electric cutter that is practical for smaller spaces, can handle all or most types of tile and thicknesses and isn't to expensive? If you do have suggestions related to your own electric cutters, could you please tell me what is good and what is bad about yours?
Thanks in advance.
As the op has asked for advice on a inexpensive electric cutter.....
Then it depends what tiles you use the most....
The vitrex or vortex..😉 as some like to call it, is imo an excellent cutter for the money....approx £100 it will cut most tiles up to 600mm without any problem but above that you would need something with a bit more beef.....like the Rubi nd200 at around £350
The vitrex can be used indoors with good dust sheeting as it has very little water spray......the Rubi can only be used outdoors .
Hope you find this more in depth post helpful....🙂
3 paragraphs long - must be Sunday!
sometimes even unable to reason. 😉
I bought the new one in Topps that has replaced the vitrex pro 750 and I think it is quality. good design and comes with a cover to protect the blade and guard when in the back of van etc. got the rubi CPC blade in it and it works a treat on porce.
Even better if they have updated it...
Yeah its slightly bigger, much more sturdy and better built. the lid is great and fits around the guide bar and no need to remove guard for blade. bench stop stops the cutter moving backwards when pushing big tiles through. well impressed with it to be honest. Anyone know of any blades better than the rubi CPC for it?
The Norton TT200em is s decent budget cutter, you can pick one up for around £135 bit more expensive than the vitrex 750 but its worth considering....heres a video
I got a Rubi nd200 and I bought a plastic mixing tray to go underneath to catch any water and splills so I can use it indoors
I got the tip from someone on the forum, when I was looking for a new wet cutter.
The mixing tray is available in b&q etc about £17.
It's also good to mix your adhesive on if your labourer is a bit sloppy in mixing
Been using one for a number of years and get yourself a plastic 9" painters tray to replace the water reservoir that comes with the cutter, it allows you to fill up more easily when water gets low.
I got my ND180 really cheap from work. Used it a few times. Hated it. Wish I hadn't got it.
Now I have a predicament..... Do I boot it over into next doors garden and pretend it wasn't me, Or do I list in on ebay, listing the good points which will all be lies and feel guilty for whoever buys it from me?
In the meantime, sticking with the angle grinder.
Gents - many thanks for your advice. I'll follow up on all suggestions and hopefully find something idiot-proof.
Thanks again!
The 180 would be fine for ur average DIY jobber
Guys - sincere thanks for your suggestions. I thought I had posted my thanks last week but it seems my post got lost.
Thanks again.
Grime,
Old Mod,
Grime,
Old Mod,
