Discuss How to cut thin porcelain ? in the Canada Tile Advice area at TilersForums.com.
Gez2312
Hi , I've recently been in a job using 750x750 5mm porcelain tiles, they cut fine on the score and snap , but trying to Maxine cut is proving a nightmare ! I have a dewalt d24000 with a Montolit Dna blade , chips them , a Rubi tc180 also with same monti blade , chips them ! Grinder with monti blade , they all usually cut perfectly with minimal or no chips but these tiles are unbelievable! Not just chips but looks like my dogs chewed at it ! Problem is I've got three wet room trays to do with them ! Any tips on how to machine cut these without savaging them would be very much appreciated! Cheers
H
hmtiling
Only used thin porc a couple of times and they both cut fine with a dna and turbo porc blade. I believe a monti squadro blade is good for the thin stuff but wait for someone with more knowledge of them to advise.
H
hmtiling
I'm referring to grinder blades
Try holding a wet sponge on the back of the grinder blade as you cut, not damp, but wet.
I'm using a marcrist AkkuMax at the moment which works well wet.
Personally don't dry cut thin porcelain.
Italy
Montolit squadro 85mm for me.
The tile in photo is 5mm
Try also resting the tile on a piece of carpet, or kerdi board - something to absorb the vibration from the blade.
It can make a real difference.
Reply to How to cut thin porcelain ? in the Canada Tile Advice area at TilersForums.com
